Send Email when alle entries has a specific status
  • May 9, 2025
  • 59 views
I need please a automation with the following logic:
I have the table 1 with the name: “table_data” and a table 2 with the name “table_email”.
I need please the following logic.
Step 1:
If in table “table_data” all existing entries with same “email” and same “finish_date” has the “status” = “Fotografiert” we must do a entrie in table “table_email”.
In table “table_email” we write the following fields from table “table_data”:
  • salutation (in table_email = email_salutation)
  • firstname (in table_email = email_firstname)
  • lastname (in table_email = email_lastname)
  • order_id (in table_email = email_order_id)
  • finish_date (in table_email = email_finish_date)
  • number_records (in table_email = email_number_records)
  • email (in table_email = email_email)
Step 2:
Each 2 minutes we proof if we have a entry in table “table_email” without value in field “email_send_date”. In this case we send a email (lets say the one with template name = “email_done”) to the email address from from field “email_email”.
Thanks very much.
hwmedhin
Forum|alt.badge.img+7
  • Retired Employee
  • May 30, 2025
 Hey there ​@KIW! Thanks for submitting such a great question! Because your question hasn't yet received an answer/solution from the Community, we've created a Support Case on your behalf with our Airtable Expert Team to get you the quickest response possible. Please check your email for follow-up and your case reference number—and continue to follow this thread as new community members tend to share answers and add knowledgeable responses regularly. Thanks!
Forum|alt.badge.img+28
Hey ​@KIW,
Are you still in need of this?
Given how Airtable works, I would probably recommend some changes in your database architecture.
eg. “If in table “table_data” all existing entries with same “email” and same “finish_date” has the “status” = “Fotografiert”” to this effect, you’ll probably want to have yet an additional table linking these records.
If still in need of the solution please feel free to reach out using this link. Will be faster to get it handled on a brief call!
