Slack notification not firing (intermittent issue)
  • September 12, 2017
  • 40 views
Forum|alt.badge.img+14
Does anyone also have similar issues - slack notification not firing?
If you configure slack notification to send notification based on views, View A -> Channel A, View B -> Channel B. Sometimes only one channel receives the update, sometimes both. When it’s not sending notifications I mean nothing at all – not even ‘skipped records’ message.
  • September 13, 2017
Are you using private Slack channels?
  • September 14, 2017
No. A public channel for the team.
  • December 10, 2019
Does Slack not post to private channels?
