Trying to apply If,then Xor logic onto a concatenated output. Please help
  • Apr 24, 2019 4:05 PM UTC
  • 13 replies
  • 167 views
Here is the code I am trying to save but keep getting errors. Any ideas?
IF(OR({Do you have all the Information needed}=“No”,{Do you have all the Material you need}=“No”),CONCATENATE({My Name},“Can’t perform”{Production Goal for the day/Week:})
Best answer by Justin_Barrett
You’re missing a comma after “Can’t perform”, and a closing parenthesis for the IF function.
A couple more tips:
  1. You can use the & operator as an abbreviated way to concatenate multiple pieces.
  2. Remember to add spaces inside literal strings that will be concatenated with field data.
  3. Building formulas in a text editor and using indentation to help ensure that you have matching parenthesis pairs makes the process a lot easier.
In your case these tweaks would look like this:
    OR(
        {Do you have all the Information needed}="No",
        {Do you have all the Material you need}="No"
    {My Name} & " can’t perform " & {Production Goal for the day/Week:}
A couple more tips:
    OR(
  • Apr 24, 2019 9:44 PM UTC
A couple more tips:
    OR(
Good tips my brother. I appreciate it.
  • Apr 25, 2019 1:34 PM UTC
A couple more tips:
    OR(
Justin,
What am I missing here: I can’t get the formula to save:
AND(
{My Name} & " Needs Information and Material to perform " & {Production Goal for the day/Week:}
IF (
{Do you have all the Information needed}=“Yes”,
{My Name} & " Needs Material to perform " & {Production Goal for the day/Week:}
IF (
{Do you have all the Material you need}=“Yes”
{My Name} & " Needs Information to perform " & {Production Goal for the day/Week:}
Justin,
AND(
IF (
IF (
  1. You’re missing a comma after each of the first two messages you’re concatenating, after the closing curly brace, and before the next IF begins.
  2. Your second and third IF functions are missing a surrounding AND for the two comparisons you’re making in each.
Here’s the correction:
    AND(
    {My Name} & " Needs Information and Material to perform " & {Production Goal for the day/Week:},
    IF (
        AND(
            {Do you have all the Information needed}="Yes",
        {My Name} & " Needs Material to perform " & {Production Goal for the day/Week:},
        IF (
            AND(
                {Do you have all the Material you need}="Yes"
Seeing so much repetition in the comparisons you’re making, I also came up with this slightly shorter version:
    OR(
    {My Name} & " Needs " & SWITCH(
        {Do you have all the Information needed} & {Do you have all the Material you need},
        "NoNo", "Information and Material",
        "YesNo", "Material",
        "NoYes", "Information"
    ) & " to perform " & {Production Goal for the day/Week:}
  • Apr 25, 2019 7:32 PM UTC
    AND(
    IF (
        AND(
        IF (
            AND(
    OR(
I like that slightly shorter version. More efficient and thus more elegant. Very inventive too by the way. You are a bad @$$. Thank you sir.
  • Apr 25, 2019 8:45 PM UTC
Justin,
I modified it a little bit by adding a 3rd condition. However, I do have a question, the below SWITCH did not print to the concatenated sentence. This was the result, “John Doe 3rd Needs to perform Installation of Prefab Headboards.” (He actually needed material)
Here’s the code:
OR(
{Do you have all the Tooling you need}=“No”,
    "NoNoNo", "Tools, Information and Material",
    "YesYesNo", "Material",
    "YesNoYes", "Information",
	"NoYesNo", "Tools and Material",
	"YesNoNo", "Material and Information",
	"NoYesYes", "Tools",
	"NoNoYes", "Tools and Information"
Justin,
Here’s the code:
OR(
The SWITCH function works based on what you feed it in the first argument. In my case, I fed it a concatenated version of the two fields you were originally using for your comparisons. While you added the third field to your OR check at the beginning, you didn’t add it to the start of the concatenation that SWITCH checks. In that case, it only mashed together the original two. None of those results are in your list, so it defaults to the equivalent of BLANK(). To work correctly, the line after the SWITCH opener should read:
{Do you have all the Tooling you need} & {Do you have all the Information needed} & {Do you have all the Material you need},
  • Apr 26, 2019 6:39 PM UTC
Thank you much!
Man I should have caught that as I understood what you did when I read the code, but like a newborn learning to crawl… What language are we writing anyway? Is this specific to AirTable? Thank you in advance sir.
Thank you much!
I don’t think it has a name. Even though the syntax and structure are similar to many other programming languages, the implementation is fairly Airtable-specific in some respects.
  • May 7, 2020 5:25 AM UTC
    AND(
    IF (
        AND(
        IF (
            AND(
    OR(
@Justin_Barrett Which text editor do you use for typing up your lengthier formulas? And does it automatically do that line indenting for you, or do you manually indent the lines yourself?
I use BBEdit (a Mac-only application), but any plain text editor will work. BBEdit doesn’t auto-indent, but then again I don’t know of any code/text editors that do. If any do support auto-indent, it would likely be tied to specific languages supported by the software. Unless someone has added native support (or an add-on) to a given editor for Airtable formulas, it’s likely to be manual no matter which tool you use.
  • May 7, 2020 5:43 AM UTC
Oh, nice! I use BBEdit too! :slightly_smiling_face: Do you have any specific language chosen in your BBEdit preferences? One that might be “relatively similar” to Airtable? Or do you just have it set to plain text? I’d love to get some semblance of color-coding that we get when using a supported language in BBEdit.
I don’t have a specific language chosen. Just plain text. Even with no specific language chosen, BBEdit still auto-completes certain symbol pairs (parentheses, square/curly braces, quotes, etc.), so that’s some small help anyway. While part of me would like to see more detailed syntax highlighting, I’ve been going without it for so long with Airtable formulas that I don’t really notice that it’s not there.
