Two way calendar sync on integromat possible?
  • December 21, 2019
  • 41 views
https://support.airtable.com/hc/en-us/articles/215275748-Using-Zapier-to-integrate-Airtable-with-Google-Calendar similar to this is a two way calendar sync on integromat possible? Like in zapier? From Airtable to google calendar?
  • December 22, 2019
Has anyone tried this? Thanks.
I haven’t tried this specific setup, but I did help a client set up a system in Integromat to sync between Airtable and Google Contacts, so my guess is that doing something similar with Google Calendar should be possible.
  • December 23, 2019
Thanks for the response.
