Two Way Syncing of Bases
I’ve synced two bases - we will call them Base 1 and Base 2.
Base 1 now shows cells A,B,C from Base 2, but I also want Base 2 to show cells D, E, F from Base 1.
Is this possible?
Forum|alt.badge.img+28
When we say synced here, are we referring to having a synced view?
If so, if you have a synced view of Base 1 in Base 2, then you should be able to do what you’re looking for
matthew_b
Forum|alt.badge.img+15
  • 63 replies
  • August 2, 2022
Hi @Sarah_Renee! If you’re still trying to solve this, you could try Whalesync. We literally just released a 2-way sync between Airtable bases today.
