Update Records Help
  • April 27, 2021
  • 37 views
Hello!
I need help updating my records with automation.
There are 2 tables:
one is a table that I use to create reports on the status of our Lights:
each location has an ID, say 1234 and associated barcodes like a light #, a controller # and a pole #
The other is a table of the entries from the tech team doing maintenance in the field.
they report what ID they worked on and if there were changes in the light #, controller # and pole #
Often the tech crew mistypes stuff and I need to review their submissions before changing our table thus not to corrupt our internal database.
So I synch the Tech’s table in my base and added a few columns like Pole # fix which copies their input as a text so I edit it if needed and I can have a comparison between what the tech inputted and what I edited it to.
I then made a checkmark which is the trigger of the automation, essentially saying that everything is good and to update the light #, the pole # and controller # in our table of the ID that they worked on.
I keep getting “received invalid inputs” error when running a test. It does not seem very complicated thing to do. if check mark, look for ID in this table, if found edit these fields.
Help?
Thanks in advance
  • May 5, 2021
Much Support, wow
here is my code for what I have gotten so far
//grab info from TF inputs
let TFinputs = base.getTable(“Fishel Inputs 2021”);
let TFview = TFinputs.getView(‘Update Leaf Lease’);
// grab record from previous input
let TFRecID = input.config();
let queryTFinput = await TFview.selectRecordsAsync(); // get all records in TF inputs
let updated_record = queryTFinput.getRecord(TFRecID.TFRecID);
let TFPoleNum = updated_record.getCellValueAsString(“Pole # Fix”);
let TFPanelBar = updated_record.getCellValueAsString(“Panel Barcode”);
let TFLightBar = updated_record.getCellValueAsString(“Light Barcode”);
let TFPoleBar = updated_record.getCellValueAsString(“Pole Barcode”);
let TFDateIn = updated_record.getCellValueAsString(“Day of Entry”);
//grab record to update
let SLlease = base.getTable(“Street Leaf Lease TESTING”);
let SLLview = SLlease.getView(‘Vanilla’);
let querySTLease = await SLLview.selectRecordsAsync(); // get all records in SLLeaselet
var SLLPoleNum
var SLLLight
console.log(querySTLease)
for (let record of querySTLease.records) {
if (record.getCellValue("Pole Number") == TFPoleNum)
CHANGE ALL INFO HERE
//SLlease.updateRecordAsync(record.id, {'Light #':[{ id: TFLightBar}], )
