Using a CRM and number of contacts?
  • January 23, 2019
  • 32 views
I’m still relatively new to Airtable and the advanced functions available. Have experimented with several of the examples available.
Would like to use a CRM that has mass emailing capability. From what I’ve read, that could be feasible with something like Mailchimp’s API and using Zapier.
Also, I’ve looked at HubSpot the free version which supports up to 1 million contacts as a CRM.
Does Airtable have similar ability to support that many contacts with upgrading?
If you store 1 contact per Record, your limit is the Records limits for every plan: https://airtable.com/pricing
Also, the most common is to store other kind of information: Companies, Interactions, Sales, etc., so you’ll get to the limit with less Contacts stored.
  • January 24, 2019
Some great templates have already been completed for you in the AT “Templates” section: Redirect Notice
Having said that hubspot is a great CRM product, even at it’s free level.
Noamsay
Forum|alt.badge.img+13
  • January 25, 2019
If you go Pro, you could simply use the SendGrid block
