Using Airtable for Process Documentation
  • Oct 16, 2017 2:21 AM UTC
  • 78 views
Forum|alt.badge.img+10
I have been testing Process St for documenting my tasks/processes to delegate to others. It is a great tool that lets me create the steps on a left navigation and then add text/images and videos to each step.
I was curious if there might be a way I could do this in Airtable. I am stuck because I can’t include text and pictures or videos on the same field.
Here is an example one I did using Process St.
  • Nov 4, 2022 1:43 PM UTC
Curious if you found the answer to your question? I was looking for a potential replacement for process street (with airtable) to reduce costs and the number of tools we use. But not sure how to easily move process street type functionality into airtable.
Ramagu
  • Feb 23, 2024 10:01 AM UTC
I found this message and would like to know if you were finally able to use Airtable for this functionality. Thanks
