Using React frontend form to connect to airtable
  • June 23, 2022
  • 29 views
Hello I wonder if you can help
I am using a react.js form to collect customer data and would like to connect this information to Airetable. this is what I have so far:
file 1 - data file
import { useState } from “react”;
import axios from “axios”;
export default function useData() {
const [data, setData] = useState(null);
const getData = async () => {
return axios.get(“/”).then((res) => {
console.log(“res.data.records:”, res.data.records);
setData(res.data.records);
return {
getData,
data,
file 2 index.js
import React from ‘react’;
import ReactDOM from ‘react-dom/client’;
import ‘./index.css’;
import App from ‘./App’;
const BASE_ID = ‘xxx’;
const API_KEY = ‘xxx’
axios.defaults.baseURL = https://api.airtable.com/v0/${BASE_ID}/Contact__form/;
axios.defaults.headers.post[‘Content-Type’] = ‘application/json’;
axios.defaults.headers[‘Authorization’] = Bearer ${API_KEY};
const root = ReactDOM.createRoot(document.getElementById(‘root’));
root.render(
<React.StrictMode>
</React.StrictMode>
I’m not sure if I am going in the right direction, or what to do next. Thank you.
JonathanBowen
@Jude - a couple of tutorials for this:
