Zapier Integration with Pipedrive
  • August 25, 2023
  • 22 views
I have an integration with zapier pulling pipedrive data into a base in airtable. Everything works as expected just one new field I created yesterday is a single select field in pipedrive with Yes or No as the selections. The test data I sent had the selection "No" but instead pulling over "No" it pulled "203" does anyone know why/how I can fix? The airtable field is set up as a short text field.
matthew_b
  • July 31, 2024
Hi! Not sure if this is still an issue you're trying to solve, but wanted to share that Whalesync just launched a 2-way sync Pipedrive integration that works with Airtable and would fix this.
https://www.whalesync.com/sync/pipedrive-airtable
