Airtable's blog post about using Airtable as a digital asset management tool
  • July 31, 2023
  • 407 views
This blog post by Airtable recommends using Airtable as a DAM (digital asset management) tool.
My company uses Airtable as a DAM, and when I was a consultant, I worked on projects involving using Airtable as a DAM. Airtable's blog article leaves out a few concepts that you should consider if you want to use Airtable as a DAM.
- Most DAMs also provide CDN (content delivery network) services. Airtable has stated that it is not designed to be a CDN. The loss of permanent attachment URLs matches the idea of Airtable not being a CDN. If you want to use Airtable as a DAM, make sure that you don't also need it to be a CDN.
- Most of the systems that I have built for using Airtable as a DAM involved at least one third-party service, and some use multiple third-party services. Due to their nature, digital assets tend to be consumed outside of Airtable. Think through how you will integrate your Airtable content with where the content will be consumed. Make sure that wherever is receiving the files can handle expiring URLs without filenames.
- Renaming attachments in bulk in Airtable is a pain. You can manually rename attachments individually. But if you want to name/rename attachments in Airtable automatically or in bulk, you have to essentially re-upload the attachment with the new name. I once had the bad luck of trying to bulk rename a view full of attachments right when Airtable was experiencing an issue with serving up attachment files and lost all of the attachments. I had to go back and find the original source files for the attachments and reupload them.
- Airtable does not have built-in support for version history of attachments. You can build a system with version history by using multiple attachment fields and/or linked records. Other commercial purpose-built DAMs have built-in support for version history. If you only care about the most up-to-date version of your assets, Airtable may work for you. If you might want version history of assets though, you will need to carefully plan your system.
- The blog article advertises "Scale without limits". As desirable as that idea is, there are always limits. All bases have record count limits and attachment space limits, even Enterprise bases.
  • March 20, 2025
how are you all managing large collections of assets in Airtable now? Have you found any new tricks or automations that make things smoother? I've been testing different ways to tag and filter images, but I'm wondering if there's a better approach to keeping everything organized, especially when working with a team.
dilipborad
Forum|alt.badge.img+23
  • March 20, 2025
Airtable can serve as a Digital Asset Management (DAM) solution for organizations with a limited volume of assets or for startups seeking to consolidate their tools in one place . This is particularly true for independent and small to medium-scale companies . Its flexibility allows for the organization of various data types, including digital assets, and facilitates collaboration .
However, when considering factors like upload and download speed, especially for larger files, integration capabilities, and API availability for extensive asset libraries, Airtable may not be as robust as dedicated DAM systems . While Airtable offers an API , it has rate limits and might experience performance challenges with very large bases and numerous API calls . The platform also has storage limits per base depending on the subscription plan, which can be a constraint for organizations with a large number of assets . The maximum file size for attachments is 5GB .
For enterprise-level organizations with substantial asset collections and complex workflows, dedicated DAM solutions like Iconik and Frame.io often provide superior performance, advanced features such as in-suite editing and sophisticated search capabilities , and better scalability . These platforms are specifically designed to handle large volumes of rich media and offer features tailored for professional media workflows and enterprise needs .
Therefore, while Airtable can be a useful tool for basic DAM needs, especially for smaller organizations, larger enterprises with demanding requirements will likely find dedicated DAM systems to be a more suitable choice.
Forum|alt.badge.img+28
Nice! Thanks for sharing ​@kuovonne.
Currently building a system involving DAM for a client. Even if sacrificing some user experience, we decided to have an integration done with Google  Drive via n8n (same could have been done using Zapier or Make).
Some context for any reader out there.
A simplified description of our current workflow would be:
1. As a new project is created, we automatically create a Drive folder for the whole project, with a specific sub-folder schema within it.
2. Attachments get stored on a specific table to such effect, which are linked to the Project.
3. Each revised version of the attachment will have it’s own record, as to store additional information for the record (e.g. time stamp, notes, status).
4. Each attachment record has a single select to choose out the corresponding sub-drive folder which it should be saved to.
5. When the Project status becomes “Complete” all attachments (actual attachment from Attachment field) for such Project get pushed to the corresponding Drive folder and the filed Attachment URL gets updated with the specific file drive url.
Is it ideal? Probably not.. Does it work? Yup!
The intention of the above is to avoid hitting a different Airtable limitation (other than the record count mentioned by you): GB of attachments per base (20 Gb, and 100 Gb on the Team and Business plans)
Would love how you are handling third party integrations for similar use cases.
  • January 28, 2026
Great example of leveraging Airtable for digital asset management. As we also review different SaaS tools at TheSoftReview, we found that flexible platforms like this can streamline workflows and improve team collaboration.
