64028members
148690posts
Community Activity
How would i capture a srtring of text within brackets?
hi there, i was trying to capture text w the mid feature for text inside a bracket in my title column imported from google calendar however for some reason it's not grabbing it. What should the formula be? The text that needs extrapolating to a diffe...
  • 18 Views
  • 1 replies
  • 0 kudos
Zapier automation, failing to add User
I have a simple Zapier automation running creating a record in Base2 after certain criteria met in Base1, this is working fine. But I need to include a User in Base2, and Zapier doesn't seem able to do that unless I have a corresponding User field in...
  • 43 Views
  • 1 replies
  • 0 kudos
Introducing Our AI Ambassadors User Group!
Hi Airtable Community,We're thrilled to introduce a new addition to our community: the AI Ambassadors User Group! This group is tailor-made for individuals who are passionate about Airtable AI and its endless possibilities. Joining our AI Ambassadors...
  • 68 Views
  • 4 kudos
Onboarding In Airtable
We are currently trying to move our hiring onboarding process to Airtable. We would like the process to be conditional, meaning that if someone is applying for a medical based position the checklist would show all the proper steps for that applicant ...
  • 56 Views
  • 0 kudos
Resolved! Create Date formula, today at hours, minutes
I want to create a formula fields equal to now() with specific hours and minutes. My formula must return a date equals to today at 18:00. Exemple today is 05/06/2024 16:12 -> 05/06/2024 18:00Thanks
  • 45 Views
  • 1 replies
  • 0 kudos
Automation run on existing records
The automation currently we are using only works on new records. Is there any way to push the automation to run on existing records in the same table? Right now, when form received, it will create new record. Goal is when form received, it will auto ...
  • 51 Views
  • 1 replies
  • 0 kudos
Announcements
Hi Airtable Community,We're thrilled to introduce a new addition to our community: the AI Ambassadors User Group! This group is tailor-made for individuals who are passionate about Airtable AI and its...
Announcements
Airtable Top Contributors | March 2024
Happy Spring, Airtable Community, and welcome to the March edition of our Top Contributors post!  Each month, we love to shout-out the incredible individuals in our community who go above and beyond ...
Announcements
Airtable is now HIPAA compliant
喙 Exciting news for healthcare providers and organizations! Airtable is now HIPAA compliant and ready to support your critical work.  We understand the importance of protecting sensitive patient dat...
Announcements
