Find record in automation using current record
  • April 15, 2024
  • 14 replies
  • 125 views
Forum|alt.badge.img+7
I have a pre-filled form that is launched from a button in a record in the Assets table. When the form is submitted, the automation is triggered. A new record is created in the Updates table. Then, there's a Find Record step where a condition is entered to find the record to be updated in the Assets table. Right now, I'm using the condition Today's Date.
That's fine for testing but what I really want to do is let the Find Record value be the record from the Assets table from which I launched the form in the first place using a button.
How do I refer to that Rec ID?
Hi Adam, couldn't get that to work either. But it does make sense that I probably don't need the Find Records action.
A record was successfully created in the Updates table, with the correct Rec ID stored in "Access Rec ID". But the "Updated Asset Last Review Date" value in the Updates table was not updated in the "Asset LR Date" in the Assets table.
I think I'll build a simpler model in a separate test base to better see what's going on.
Thanks for your ongoing guidance.
Roger that.  I've put together a working version of what I think you're trying to do here:
Form link prefills the record ID of the Asset record, on form submit it creates a record in "Updates" which triggers an automation that updates the "Asset" record with a link to the new "Update" record
Forum|alt.badge.img+31
Hm, if I were you I'd try:
1. Create a field in the "Updates" table called "Asset record ID"
2. In your prefill URL formula field in "Assets", prefill the new field from step 1 with the Asset record's "record_id()" value
This way the submitted "Updates" record will include the record ID of the record from the Assets table which you clicked the button on, and you can use that record ID for your search
I'm not entirely clear on the use case, but you could also just link them together directly too?
jsep
Forum|alt.badge.img+9
  • April 16, 2024
Adam's solution should work, and you can also hide the "Asset Record ID" field in the form since it is for your use only.
To pre-fill form fields, follow this guide: Prefilling a Form via Encoded URL
To hide the "Asset Record ID", use the visibility rule with two conditions, as shown in this screenshot.
If you need help implementing this solution, fell free to schedule a free call with me.
  • April 16, 2024
Hi Adam, I pretty much had the tables set up with the Rec ID available and I've now added that Rec ID field to the pre-filled form. But I'm still stymied about how to point to the Rec ID value in the Automation,
Shouldn't I be able to set a condition that refers to that Rec ID value? in the Conditions section above I can only add a string as opposed to a value in a field.
I'm sure I'm missing something fundamental. I do need the Find Record step, right?
jsep
  • April 16, 2024
@CharlieMullin  you have to dynamically filter the record using the form's "Asset Record ID".
Like this:
I hope this helps! If you need help implementing this solution, feel free to schedule a free call with me.
  • April 16, 2024
Like this:
Totally forgot about selecting Dynamic to present the fields. Thanks for that.
Now I'm getting this error:
Not sure what that means. Asset Rec ID is a short text field, so should be OK. Here are the two relevant fields:
Asset Record ID was submitted via the pre-filled form. Original Asset Rec ID has a formula to fetch its value from a Rollup field that contains the Rec ID from the Assets table. You can see that those values match (the last three records.)
Thoughts?
jsep
  • April 17, 2024
Thoughts?
Sorry I don't see the error in your reply.
Feel free to schedule a free call with me, and we'll make it work.
re: Shouldn't I be able to set a condition that refers to that Rec ID value? in the Conditions section above I can only add a string as opposed to a value in a field.
Yeap, you need to set a condition to refer to that value and you do need the Find Record step.  In your "Assets", create a formula field called "Record ID" with the formula `record_id()` and use that in your Find Record step.  Specifically, the Find Record step will look for records in "Assets" with a "Record ID" value that matches the value of "Asset Rec ID"
As an aside, I'm kind of curious what the formula is for the field "Original Asset Rec ID".  Not related to the stuff I mentioned above mind you, I'm just wondering how you set that bit up
  • April 17, 2024
Hey Jsep, here's that missing screensot with the error:
See the Filters error msg at the bottom.
  • April 17, 2024
Here's the Original Asset Rec ID properties:
  • April 17, 2024
I think Find Records is fine now, but I still have an error in Update Record. Checkout the two screen shots:
Thoughts?
Thoughts?
Hm, in the "Update Record" step, instead of using "Original LMSC Rec ID", could you try using "Asset Rec ID" instead?  If that works you won't need the "Find Record" step, sorry about that
  • April 18, 2024
  • April 19, 2024
Alright Adam, I have things working now. Really, my tables are glutted and this is such a simple thing to do once I peel away a lot of my unnecessary items. Linking properly between the two tables was key.
Thanks for all your help!
