Need some help for custom Slack script
  • November 19, 2024
  • 56 views
Hi, I am trying to make a custom Slack script for my team where I can send the invitations to the users once the form is filled. For that I am trying to make a script that has an input field like Slack action where you can connect your account, select workspace and send the invitation. But I am not able to find how can I make those custom drop down? Do I have to code that out or can I use some pre-built things?
Dimitris_Goudis
Forum|alt.badge.img+20
Hey @Siddharth007,
Did you try the slack actions on automations settings? These options are a available there.
Feel free to reach out to me for solving this with no commitment.
Thanks
Dimitris
  • November 19, 2024
Hey @Dimitris_Goudis ,
Yes, I looked into the Slack actions. I have only two Slack automations available - Send a message, Send an actionable message. It's not the same as sending the invite to the users. I don't have a joining link. We are individually sending users an invite to join the slack workspace.
Dimitris_Goudis
For the initial invitation I would recommend to use an automation service like zapier, make or latenode. This will do the job for you.
Great pleasure to guide you on these solutions.
