Respond slack actionable messages problem
Why I cant reply to actionable messages on Slack?
When clicking in slack I always keep receiving the same reply.
"You do not have access to this Airtable record, or it has been deleted"
Thats impossible as Im the owner of the base and workspace. How may I fix this?
Thanks
Saravanan_009
Forum|alt.badge.img+15
Airtable API Rate Limits: If you're performing a lot of actions through Airtable's API (like via Slack), you might hit a rate limit, which could result in errors like the one you're seeing. Check if other API-related actions are functioning properly.
Saravanan_009
You can create a Slack channel and add a particular user to it. In the Slack channel, you can set up notifications for whatever you need. Then, in Airtable automation, instead of choosing "Send to a user," you can select "Send to a channel" to add notifications to that channel.
If you need anything, please share your base, and I will help you.
  • August 13, 2024
Hi! Im already sending this to a channel not to a user. And also I have enterprise plan, no I have no API limit problems. Its pretty wierd to problem I have.
