How to Move Columns in an AirTable Base
  • September 12, 2020
  • 501 views
I have a base with columns (fields) in a given order horizontally across the page. I want to move some of these columns so that the are in a different order across the page. How do I do that?
Best answer by Terry_Liberty
Hi Terry
You just need to go to the top of the column (field name) area and click and drag to were you want to place it.
This works for both desktop and mobile device versions.
Hope this helps.
If so, can you mark it as a solution, so others can find it useful, too.
Thank you,
Mary Kay
Ha! Too easy. I could have thought I’d tried that.
Thanks.
Forum|alt.badge.img+20
Hi Terry
Hope this helps.
Thank you,
Mary Kay
Hi Terry
Hope this helps.
Thank you,
Mary Kay
Thanks.
  • September 13, 2020
Thanks.
Hi @Terry_Liberty
No problem.
Can you mark the solution in my reply, too?
Thanks,
Mary
