Need help with Typeform integration
  • May 20, 2020
  • 6 replies
  • 72 views
Typeform offers an Airtable integration, and I’ve managed to map my fields, except I need to capture the timestamp of the date/time that the Typeform was submitted. Typeform does capture this data and calls it “Submit Date (UTC)”. I wish to map the data of that field to a field/column in my Airtable.
Have anyone figured this out? Is it not possible?
Best answer by Mohamed_Swella1
I’m not sure I understand what you mean because Typeform doesn’t populate the Airtable with the submit date for me. The submit date wasn’t available when configuring the integration.
I understand your concern. However, there is a field called Created Time that can help you solve this issue. You dont have to make it from Typeform, you can do it directly in Airtable.
Check the support article and Im sure it will solve your issue.
Mohamed_Swella1
Hi @CW_Research,
Welcome to Airtable Community! :grinning_face_with_big_eyes:
How about instead of using this date you make a field with the option Created Time directly in Airtable?
BR,
Mo
  • May 22, 2020
Hi @CW_Research,
BR,
Mo
Hi Mo - I have a field in my Airtable called “Date Added”, and I’d like to populate it automatically with Typeform’s “Submit Date (UTC)” field value.
Mohamed_Swella1
Yes I understand, this would be the same date anyway since when the Typeform is done it will populate Airtable instantly and you will get the date anyway.
  • May 22, 2020
Mohamed_Swella1
  • May 23, 2020
Ah! Thanks for the link, now I see what you mean! That worked, thank you!
