Mar 14, 2022 01:41 AM
Hi everyone.
We all know the script in the airtable scripting examples to create a running total.
The script below is as such:
// change these names to pick a view:
let table = base.getTable('Marketing');
let view = table.getView('Grid view');
let result = await view.selectRecordsAsync();
let runningTotal = 0;
for (let record of result.records) {
// change the field names here to adapt this script to your base
runningTotal += record.getCellValue('Amount');
'Running Total': runningTotal,
The issue with the script is that it takes the running total from the previous row and adds the number of the current row to create the running total for the current row.
I was wondering if there was a way to filter based on linked records.
That is: for the current record, you only add the current number to the sum of running totals of linked records.
Would anyone know how to do this?
Solved! Go to Solution.
Jul 11, 2022 11:52 PM
It seems like you mean grouping by customer.
I would solve that via Map JS function, but it needs whole script re-write.
You may transform current:
add sort to selectRecordAsync
, by customer, then by date (check API example)
insert new variable,
let currentCustomer='';
reset counter after each customer change
if (currentCustomer!=record.getCellValueAsString('customerfield')) {
currentCustomer=record.getCellValueAsString('customerfield');
runningTotal = 0 }
(that should be inside loop before
runningTotal += linkValue(record.getCellValue('Amount'))
Jul 07, 2022 08:28 AM
Hi
insert this function somewhere upper the loop.
let linkValue=a=>a? a.map(x=>Number(x.name)).reduce((b,c)=>b+c):0
instead of runningTotal += record.getCellValue('Amount')
use
Jul 07, 2022 08:19 PM
Jul 10, 2022 07:20 PM
sorry for late response
I suppose I misunderstood initial settings. What’s the type of Amount field and the field, which it links?
that’s how it should work
Note that in my example RT is string so I’ve added type conversion.
But that’s not related with your error message.
await table.updateRecordAsync(record.id, {
‘Running Total’:runningTotal.toString(),
Jul 11, 2022 10:25 PM
Dear @Alexey_Gusev ,
In my case
So I want to do running total based on linked record of customer. So the script must be able to detect previous row and whether it’s the same cust (add) if no (will take the current row and continue adding subsequest rows).
Do you have any idea how to accomplish this?
Many thanks in advance!
runningTotal = 0 }
Jul 12, 2022 01:45 AM
Hi @Alexey_Gusev ,
let table = base.getTable('Sales');
let view = table.getView('Overall');
let result = await view.selectRecordsAsync({fields: ['Sales Amount']});
let customerField = await view.selectRecordsAsync({fields:['Customer'],
sorts: [
{field: 'Customer'},
{field: "Sales Date",direction:"desc"},
let currentCustomer = '';
let linkValue=a=>a? a.map(x=>Number(x.name)).reduce((b,c)=>b+c):0;
console.log(record)
if (currentCustomer != record.getCellValueAsString('Customer')) {
currentCustomer = record.getCellValueAsString('Customer');
runningTotal = 0
runningTotal += linkValue(record.getCellValue('Sales Amount'));
'Cumulative by Customer': runningTotal,
However I am getting this error now.
Jul 12, 2022 05:24 AM
That’s because you are using result variable in your loop, which has another field.
instead of
let result = await view....
sorts: [
You should use:
let result = await view.selectRecordsAsync({fields:['Customer','Sales Amount'],
sorts: [ {field: 'Customer'}, {field: "Sales Date",direction:"desc"} ]});
btw, I cannot understand why you are sorting date descending, because if you want it to be like on your picture, you should remove direction:"desc"
Jul 12, 2022 05:54 AM
Yes, I have removed the direction and it is working now.
Thank you so much! :grinning_face_with_smiling_eyes:
Jul 12, 2022 07:20 PM
Hi @Alexey_Gusev ,
I have one LAST question :grinning_face_with_sweat:
Instead of running through all records, I just want to update those new records or where cumulative amount field is still empty.
let currentAmount = record.getCellValue('Cumulative by Customer');
// skip records
if (currentAmount == null && currentAmount == '') {
continue;
But it still loops all records. Is there a way to filter it and only run for new records instead?
Jul 13, 2022 09:57 PM
It should be
if (currentAmount !== null) {
continue;
Jul 14, 2022 12:54 AM
Having a read through this thread, when I anticipate that my code will be filtering records - I save and exit my code, and then head to the Airtable Views, create the filtered view to see the actively filtered records live (and check that they’re what I’m expecting) - and then use that newly created View in my Script/Automated Script.
I try to leverage as many non-coded elements in Airtable as possible. There are no doubt pro’s and con’s to hard coding things, but just through my experience I often enjoy to use the visual aids, such as a Table View, to then drive my code.
Aug 07, 2022 05:21 AM
Totally agreed.
My automations usually zero-code or low-code.
Typical script is:
automation lets us manage 1&3 and in many cases it has enough ways to do 2, without code.
usual case - maintain links between 2 tables. so I create view “where link is empty” (lock it and set warning ‘don’t touch’) and set trigger to “when record enters view”.
just for scripting exp…
continue;
that’s correct. but…
if (currentAmount) continue
is enough
Aug 07, 2022 09:57 PM
Appreciate your tips @Alexey_Gusev
I am now trying to improve the code, now instead of running all records, I want to store the last record that has cumulative amount and add it to new record.
I am trying to get the last cumulative amount of “00054408” and inserted below code above the if statement.
let previousAmount = result.records.indexOf(result.records.filter(item => item.getCellValue(‘Cumulative by Customer’) > 0).pop())
But it is showing error. Any idea why or how to achieve this using other methods?
Thanks
Aug 09, 2022 11:54 AM
in such cases I usually split complex statements to debug, like
let filtered=(result.records.filter(item => item.getCellValue(‘Cumulative by Customer’) > 0)
let last=filtered.pop()
and so on
I have no time to check, but I think you have error because result.records is array that doesn’t contain cell values. As i remember, it’s an array of objects like {‘id’:XXX, ‘name’:YYY}. So your item.getCellValue(‘Cumulative by Customer’) can’t be part of it
there are plenty of ways to achieve your goal. that’s how I did something alike, with using Index, , and it’s not a better way.
(I quoted part of script that contains necessary action)
const query=await table.selectRecordsAsync({fields:[field]});
const index=arr=>arr.indexOf(Math.max(...arr));
const val=query.records[index(query.records.map(compare))].getCellValueAsString(field);
output.text(val)
Aug 09, 2022 09:21 PM
Thank you so so much. In the end I don’t use index/array but I manage to filter out the last amount of a filtered array and store that amount in a variable and now it is working!
Airtable is blessed to have someone like you in the community!
