Automation Script stuck on Pending
  • April 24, 2023
  • 260 views
I've seen issues opened about this two months ago but we're experiencing this issue now.
I tried leaving the script for an hour and the state doesn't change, though if I run a test of the automation, everything works.
The status page shows there are no incidents.
I've also tried creating a new automation that only runs the following script and it still gets stuck -
Best answer by Juliana11
Hi there! Automations stuck in pending status are typically a result of overall base performance/load. If the trigger is "When a record is updated," for example, and you're using the API to programmatically update records at a high frequency, it could overwhelm the base and cause many pending runs. That said, if the workflow is stuck with only a handful of pending runs, that might be something which would necessitate a support case so that we can take a closer look at the particulars—just let me know.
Forum|alt.badge.img+13
  • April 26, 2023
  • May 3, 2023
Apparently one of our operations trigger lots of automations at once, making the rest of the automations stuck.
However, I do think `Automations` is a weak side of AirTable, as there's no indication of any queues/limitations and what so ever, making such things demand investigation instead of it popping out like it probably should.
