May 09, 2022 07:30 AM
Hello all,
I’m trying to figure it out for weeks to solve this problem.
Base A : I want to get address data (zip code) + buying rate from this base
Base B : I want to get address data (zip code) + selling rate from this base
Base C: When I write that specific address/zip code and it matches with the address in Base A and Base B, I want to see buying rate and selling rate in separate columns automatically.
So it is like;
zip code base A + zip code base B = buying rate base A + selling rate base B in base C
That would be great if you could help me to solve this issue because I’m about to lose my mind :slightly_smiling_face: What is the right way to do it? Is it by a formula? Is it by something else? Please help me.
Thank you.
Solved! Go to Solution.
May 09, 2022 08:06 AM
Hi @nilay_gunay,
AFAIK the only ways to get data from another base are synced base, scripting or custom app over the API.
Have you looked into syncing Bases A and B into Base C. Then using look ups to find the synced data?
Hi @nilay_gunay,
May 09, 2022 07:49 PM
Hm, any reason why they need to be different bases instead of tables in the same base?
May 10, 2022 11:59 AM
Thank you so much! I was looking for the answers in formulas but I synced the table in Base C and just used look up field, AND it worked. Thank you sooooo much!!!
