Using a linked column as part of a formula
  • November 18, 2018
  • 12 views
I have a “Rates” table that I am linking into a column on an “Estimator” table. It seems as though I can’t use the linked-in Rate data in a formula on the Estimator table. Is that right??
  • November 19, 2018
You have to create a lookup field on Estimator that points to the field in the Rates table that has the data.
From there, reference that lookup field in your formula.
