Interface Chart Value's are Displaying in Wrong Order
  • February 7, 2022
  • 6 replies
  • 156 views
Hi there.
I’m facing a problem in some of my interfaces where the value’s are not appearing in the right order whether I change it from Ascending to Descending.
For example. I have a bar chart as below where all the weeks are in the wrong order:
I’m pulling the 'Week’s from a table as follows. Weeks are a linked record.
Can someone explain what I’m doing wrong here?
Thanks
Dan
  • March 2, 2022
Hey Dan,
Did you get this figured out? We’re having the same issue
  • April 21, 2022
Bump. Also having this issue
  • May 27, 2022
Similar problem here. I need the ability to sort a line chart by a non numeric field.
  • May 28, 2022
There are several different ways to set the sort order.
  • Alphabetical sort (This is what happens when none of the other situations apply.)
  • Numeric sort (This requires a number field, not a text string that looks like a number.)
  • Date sort (This requires the field be a date field, not just text string that looks like a date to a human.)
  • Select choice sort (The order of select choice as defined when configuring the field. This requires that the value be a select field.)
  • October 27, 2022
Can I confirm that this sorting cannot be done within the interface? That the x-axis choice must be one of these that you listed for the interface to not automatically revert to Alphabetical? My X-Axis is a column with month and year (AUG-22) which cannot unfortunately be sorted as a date (it’s text) without adding in an irrelevant and confusing day.
  • November 22, 2022
For Jess…
Add a date field to your data. Pick the end of the month. You can then hide that field. Now, in the interface use the Date field as your X-Axis and change the “Bucket by” to Month. That’s how I did it for your use case.
