Interface Charts - second y-axis has the incorrect units
  • October 21, 2024
  • 112 views
Forum|alt.badge.img+8
Is this a bug, or am I missing something?
My left side axis (first y-axis) uses a formula percent field. But I want the second y-axis (Y-axis (right)) to just be standard numbers in order to show the COUNT. The percents showing up don't make sense there. Is there a way for me to fix something I'm doing?
Best answer by jills
This was, in fact, a issue on Airtable's end. They fixed it!
Forum|alt.badge.img+31
Hmm not sure if it helps but I got it looking like this:
Link to base
  • October 22, 2024
Link to base
Looks like you've got the same issue with yours. Number of records on the right side is showing in percentages instead of a number count.
  • January 28, 2025
