AirTable work with Mac Contacts?
2087 1
Annamarie_Pluha
Not sure if this belongs here or in Integrations. I would love to be able to put in a name, phone and email in airtable and have it export to my Contacts dbase. Is this possible? How to do it?
Thanks
Annamarie
Hi Annamarie
I don’t think you can do this directly - but you can use Zapier to copy new contacts into other Web contacts apps - I have tried it with both Office 365 and Google Contacts. You should then be able to connect your Apple Contacts app to either so that your contacts appear in the Contacts app.
Hope this helps?
Julian
