How do I create click to dial phone numbers from a Phone Number field in my table
  • January 16, 2023
  • 12 replies
  • 515 views
So I have a Phone Number field containing phone numbers in this format: (123) 456-7890, and I want to automatically convert those numbers to links so that users can click on them to dial.
Best answer by remekoh
Maybe it was how I worded my question, but this problem has nothing to do with clicking on phone links within Airtable.
However, here's the solution that worked for me, just in case someone else is having a similar issue in the future:
1. Create a Formula field
2. Paste the following formula:
CONCATENATE('<a href="tel:' & {YOUR FIELDNAME} & '">' & {YOUR FIELDNAME} & "</a>")
Hope that helps!
Shannon_Bradley
Forum|alt.badge.img+15
My phone #'s are in that format, and when using the app on my phone it already works the way you describe, tapping that field I have the option to call or text. Are you talking about having that ability in the web version?
  • January 16, 2023
On the desktop, you must have a call application. Google Voice has a free plan. I use the $10/ month plan. It makes all numbers callable from my desktop.notebook. The paid version of voice adds a couple of other features.
or
  • January 16, 2023
When you say when using the app on my phone, are you referring to the Airtable app?
I'm looking for a solution that allows for users of my web app to click that field and be able to dial that number...
I tried this solution but it didn't work for me...
  • January 16, 2023
or
Not really sure this applies to my question, but thanks for chiming in...
Shannon_Bradley
Yes that is what I referred to. I feel that the user would need a desktop application to call from a separate web app? But there is so much ability AT has I don't know....following to see if someone else as the answer you seek!
  • January 17, 2023
A call application is required on the desktop.  From my desktop or notebook, I can call all numbers. Other features are available in the paid version of voice.
  • January 20, 2023
Hope that helps!
  • January 21, 2023
What call system do you use? I use Google Voice Business for $10/mo.
  • January 22, 2023
Hope that helps!
Please provide an example of actual input and output.
  • January 26, 2023
Phone Number FieldFormula field with above formula
(123) 456-7890<a href="tel:(123) 456-7890">(123) 456-7890</a>
TheMortgageMeister
Forum|alt.badge.img+11
Hope that helps!
It is not working for me, where are the links appearing for the users to click? in a gridview or interface?
  • June 9, 2023
  1. 'Determine the RowIndex of the Row whose LinkButton was clicked. Dim rowIndex As Integer = Convert.ToInt32(e.CommandArgument)
  2. 'Reference the GridView Row. Dim row As GridViewRow = GridView1.Rows(rowIndex)
  3. 'Fetch value of Name. ...
  4. 'Fetch value of Country.
