Issues with maps. Wrong address
Topic Labels: Extensions
1184 1
Promis_Jure
i created a map sync with a “stores” table.
the stores are not placed at the right adresses.
Capture d’écran 2020-10-22 à 11.17.10
You might want to share more details such as the configuration of the map integration and the location differences for a few examples. Providing a single example at a zoom level that lacks any topography detail makes it very difficult to help you.
