Need help setting up first form!
  • August 29, 2019
  • 46 views
This is my first time using Airtable, started just today.
I’ve been trying to find an answer but have so far been unsuccessful.
  1. Is it possible to create a multi step/section/tab form?
What I mean is - I have 5 topics (as shown below), a user can navigate to the next section only if s/he completes the previous section/tab. Each section/tab has a set of different types of questions, along with a next/previous buttons.
  1. Profile
  2. Customer Service
  3. Brand Awareness
  4. Product/Service Quality
  5. Gift!
  1. Can I design the placement of fields?
    At the moment, everything is vertical - 6 rows, 1 column (couldn’t post image). I’d actually like 3 rows and 2 columns.
Thank you so much! :slightly_smiling_face:
Best answer by JonathanBowen
Hi @Rohan_Ganachari
No - but you can link from one completed form to another (requires a paid AT plan), so you can get a multi-step process this way:
5 linked forms imply 5 AT tables, so the trick here is linking the different submissions to a single entity. This process is easier if you use a 3rd party form solution - Typeform or Jotform (with Zapier in the middle). Have a read of these posts covering similar topics:
Unfortunately not (with AT forms, at least), other show/hide or vertical order.
JB
JonathanBowen
  • August 29, 2019
Hi @Rohan_Ganachari
JB
  • August 30, 2019
Hi @Rohan_Ganachari
JB
Try Jot Forms to add flexibility and logic - during data entry and data dissemination to multiple tables/bases etc.
