how to connect Airtable to carrd.co for sending no reply Airtable email Automation
  • December 13, 2024
  • 0 views
Hi to everybody,
I would like to do everything with my web page CARRD.Co and Airtable. Do you think it is possible? I found a person who linked this page (which I attach) to carrd.co. By entering the email in the appropriate space and clicking the button, the user will find in the email box (see first attachment) the email sent via Airtable with a link that will allow him to download the pdf files and another link that will allow him to download a form (google moduli) to fill in to make other requests or leave comments. It would seem everything was done with Airtable and carrd.co; it does not seem to also use MAKE or something else like that.
Do you think is it possible?
if it were possible, what system should be used with Airtable to connect carrd.co with airtable?
Thanks a lot to anyone who helps me out of this puzzle that is driving me crazy
Looks like caard allows you to create an Airtable form: https://carrd.co/docs/forms/setting-up-a-custom-airtable-form
So it's possible their setup is:
1. User submits their email address via that form
2. New record gets created in Airtable
3. Automation triggers that sends out the email
Andres_at_Conne
  • 48 replies
  • December 20, 2024
Probably the link points to the same Carrd URL.  So there's no "integration" per se, just for each form submission, each user receives an email with a link to the same URL.
Typically used with lead magnets.
  • December 20, 2024
Thanks for your replies.
Regarding Andres' last suggestion, in the case you were talking about, how can I connect carrd.co to Airtable? Could you please give me a step by step indication?
