I'm setting up an automation to find records from webhook data. The field I need to match appears grayed out by Airtable with an error, "No valid nested options". Please see image.
I've never seen this error message before, and a google search was of little help.
Can you help explain what this error message means and how to resolve it?
Find Records automation - Need help with strange error: "No valid nested options"
Best answer by Sho
Find records can only be compared between common variable types.
Only strings can be selected for string fields and numbers for numeric fields.
