I have the following problem of not beeing able to merge Orders in our internal pipeline.
We are getting Orders from our Hubs for Equipment, which need to be packed and shipped in batches.
The Script should be able to merge same items ordered for the same Hub multiple times or split if different items ordered.
I created the following 2 cases to make the request visible.
Case 1: different items
Input Table "Input Rider Gear Orders"
View "Pending"
Order 1
Column: "Order Number" Value: "17884"
Column: "Hub Code" Value: "nl_til_west"
Column: "Full Name (from Master Data combinations)" Value: "Winterset - Male - M"
Column "Quantity Pick" Value: "1"
Order 2
Column: "Order Number" Value: "17984"
Column: "Full Name (from Master Data combinations)" Value: "Winterset - Male - L"
Output Table "Rider Gear Output Test"
Column: "Pick 1" Value: "Winterset - Male - M"
Column: "Order ID 1" Value: "17884"
Column: "Quantity Pick 1" Value: "1"
Column: "Pick 2" Value: "Winterset - Male - L"
Column: "Quantity Pick 2" Value: "1"
Column: "Order ID 2" Value: "17984"
Example 2: Same items ordered
Order 1 Column: "Order Number" Value: "17884"
Order 2
Column: "Order ID 1" Value: "17884, 17984"
Column: "Quantity Pick 1" Value: "2"
How can I make sure to achieve the stacking of orders in case of the same items?
