How Do I Clear a Records "Linked Field" Value Using Script?
I am really struggling to do something as simple as "clear" a records linked field value.
I have tried...
table.updateRecordAsync(r, { "Linked Field": [{id :''}]}); table.updateRecordAsync(r, { "Linked Field": [{id :null}]}); table.updateRecordAsync(r, { "Linked Field": []});
If anyone can let me know how to clear a records linked field that would be amazing.
Thanks
Best answer by Ben_Young1
Hey @Mono
Someone asked a similar question in this thread.
The short answer is that you need to pass an empty array to the linked record field.
It should look like this:
table.updateRecordAsync(recordId, { "linked_record_field": [] });
Ben_Young1
Forum|alt.badge.img+20
  • 520 replies
  • February 10, 2023
Hey @Mono
Forum|alt.badge.img+27
  • 6001 replies
  • February 11, 2023
Your third version was correct. You probably got tripped up in an issue today when scripting was not working and didn't realize that it was a problem with Airtable and not your script. It wasn't reported on Airtable's status page, but multiple users were experiencing issues with previously working scripts today.
  • February 13, 2023
Thanks All - Sending through the blank array is indeed the answer.
Looks like the issue with Airtable on Friday was stopping it from working.
