Looking for a no-code frontend for PostgreSQL data entry. Am I in the wrong place?
  • January 18, 2024
  • 5 views
I'm looking for an alternative to MS Access which will allow our employees to enter data through forms, with basic features like lookup tables and direct access to an AWS hosted PostgreSQL instance.
Does Airtable do that? It seems like Airtable needs to ingest all data into its own 'base', but I'm really not looking to do that.
If not, I'd appreciate any suggestions for data entry software.
BillH
  • 178 replies
  • January 18, 2024
If you're committed to PostgreSQL you probably are in the wrong place.  You might want to check out Noloco to get a better idea on how to scope this (they do offer a free trial for 30 days).
