Using pagination and offsets Javascript module
Hey all, I am attempting to use the Javascript API to get records in a Node.js server from a base with 10,000+ records. I have used the offset parameter in the past with CURL but am not getting an offset when my query returns. Here is the query at the moment:
    const results = await productsBase('Products').select({
      filterByFormula: `OR(FIND("${BRAND}",{BRAND}),FIND("${PRODUCT}",{PRODUCT}))`,
      maxRecords: maxRecords,
    return await results.all()
Thanks in advance!
  • 5995 replies
  • August 13, 2021
How many records do you expect to get, and what is maxRecords set to?
  • August 13, 2021
Hey Kuovonne, I would like it to get 100 records at a time. maxRecords is set to 100 at the moment.
  • 5995 replies
  • August 13, 2021
Try increasing maxRecords. The page size determines the number of records per page. Max records determines the total number of records across all pages.
  • August 13, 2021
In that case would switching maxRecords to pageSize and using .eachPage instead of .all be the right approach? Somthing like:
  pageSize: pageSize,
let i = 0
return await results.eachPage(
  function page(records, fetchNextPage) {
    console.log(':~: products.js:fetchProducts records ', records)
    if(i === pageNumber){
      return records
    } else {
      i++
      fetchNextPage()
  function done(err) {
    if (err) { console.error(err); return; }
If that is the right approach, how do I return the records from the function? My console log is showing that it is itterating correctly but the records are not being returned.
