Hello !
I have the same problem trying to Group by on a Single Select field.
Thank you !
Hello again @Andy_Scanlon !
I just found a workaround. The problem is that the Group by function doesn’t seem to work with Single or Multiple Select fields.
What I did is create another column with a formula just to transform the Single/Multiple select field into a string :
{Your field}
You should now be able to Group by on the new column you created !
Already have an account? Login
No account yet? Create an account
Sorry, we're still checking this file's contents to make sure it's safe to download. Please try again in a few minutes.
Sorry, our virus scanner detected that this file isn't safe to download.
