Looking for UK based Airtable Experts to help with a short term project
  • December 18, 2024
  • 4 views
I,m building a flow chart that essentially id like created in Airtable, think of a job card to be used on site that has tick boxes, and photo uploads that feeds into a central form amongst other things.
Does anyone have any availability before the end of 2024 atall?
Thanks in advance
Jason
Forum|alt.badge.img+23
Hey @JasonD!
Sounds like something that can be achieved within such timeframe!
We are not based in UK, however we do work with multiple clients from UK seamlessly. If location is a dealbreaker for you, I can still connect you with top developers over there :D.
Feel free to reach out via private message, or else schedule a brief call using this link to go through your specific needs and get to know each other!
Forum|alt.badge.img+28
Hi Jason, I'd be happy to help with this and have availability before the end of the year!  I work UK hours but aren't based in the UK I'm afraid
I'm pretty active on the forums so you can get a grasp of how I work from my activity here as well as some reviews, and I've got a bunch of example projects that you can find here!
If you think I could help, here's a link to schedule a free half hour call to work on stuff together and see if we're a good fit
Best of luck either way!
Dimitris_Goudis
Hey @JasonD
I am doing a live building session where we can build on the call your base. On the call, I can explain to you how to do important actions on Airtable, and we can complete your projects live in that meeting.
Happy to have a 30minutes conversation with no commitment to show you how you can get started.
This is my calendar link: https://cal.com/dimitrisgoudis/meet-dimitris
Thanks
Dimitris Goudis (3 Nuggets.io
Sachin_191
Forum|alt.badge.img+9
  • 95 replies
  • December 20, 2024
Hey Jason,
I’d design a streamlined "Job Card" system tailored to your on-site needs. This will include interactive tick boxes for task tracking, photo upload fields for visual documentation, and a centralized form that consolidates all job data into a user-friendly dashboard. Leveraging Airtable’s relational database, I’ll connect the job cards to other relevant forms or records, ensuring everything feeds into a cohesive workflow. Advanced Airtable automation will send notifications, generate reports, or trigger other actions as required to keep your process efficient and intuitive.
