Can I count how many times something appear in a range of entries?
I have a sheet called fixtures and it is filtered into seasons, each entry represents one match and has players listed that played in a match. I want to be able to count how many times a player appeared in a each season. Any ideas? The seasons are currently identified by a ‘single-select’, and each fixture is numbered individually regardless of season.
Hi @Sam_McDonnell,
Are the players linked to - and listed in - another table? If that’s the case, that will make it a lot easier.
Greetz,
André
  • 8 replies
  • May 10, 2018
Andre_Zijlstra wrote:
Hi @Sam_McDonnell,
Greetz,
André
Hi @Andre_Zijlstra , yes all the players link to another table.
Hi @Sam_McDonnell,
I tested 2 tables (Fixtures and Players) of an imaginary u11 team. 7 players are on the Staring VII and 3 are subs. It would look like this:
Fixtures:
Players:
Count fields give you the number a player is selected in Starting VII and Subs.
A formula field adds up both the Count fields. And added to this, at the bottom you see numbers that:
  1. you should be able to divide by 7
  2. you should be able to divide by 3
  3. you should be able to divede by 10
Regards,
André
  • 8 replies
  • May 11, 2018
@Andre_Zijlstra thanks, that’s very similar to what I have. The main difference is I have 13 seasons of fixtures with each season identified by a single select field. I’m looking to count players appearances by season, any ideas?
The easiest way would probably be to create a formula field per season / for the starting players and a formula field per season for the subs. Something like this:
Of course you would need a field to identify the season.
Formula for the start squad:
In the table where you find the players, you need Rollup fields (per season, start, sub).
For the starting players:
For the subs:
And that will like like this:
Of course you may choose the option to create a view per season. In that view you can hide the fields that contain data of other seasons.
Hopefully that will work for you!
Greetz,
André
  • 8 replies
  • May 14, 2018
For the subs:
Greetz,
André
Thanks @Andre_Zijlstra, that looks like the route I should be pursuing. One difference is I have 11 fields for the different starters rather than linking them all in the same field. I’m sure there’s a work around for this. Thanks again for your help.
Are those 11 fields related to the positions on the field? In other words, do you bring a sub into a position or just one player for another?
  • 8 replies
  • May 15, 2018
I just have three additional fields for the subs, and discount any subs who were not brought on.
Regards,
Sam
