Zapier - Serach by Record ID (or RECORD_ID()) [ SOLVED ]
Using Zapier, I am trying to lookup the “full name” field of a linked record by using the record id of that linked record. The record ID is the relevant record is returned by Zapier - so I should be home and hosed, right?
However, This post seems to suggest that I cannot serach by record id unless I first define a “record id” field in my linked table (using the formula RECORD_ID()).
UPDATE
This works
RECORD_ID()="<TriggerValue>(Step 1: Record Id)<TriggerValue>"
Hey Alex (or anyone reading this),
Would you mind sharing where you inserted that equation in Zapier’s “Find Record” step? Having some trouble making it work.
  • February 18, 2025
It would look something like this:
