Contractor Management: Role/Project % Allocation
  • April 14, 2019
  • 20 views
Hi all
In early stages of assessing whether Airtable is a good fit.
I work with a large freelance base at our creative studio, and need to allocate freelancers across several projects.
For example:
Laurie will be allocated 10% to project A, 20% to project B, and 70% to project C.
Is there a way to do this so I can see in the Calendar setting:
  • Laurie’s project split across the 3 projects
  • Which these projects are, which may have different date durations
At first glance at the Contractor template, I can duplicate the freelancer several times - but this can start to look messy when the calendar fills up and does not clearly show the assigned project or % allocation.
Thanks in advance for any tips!
  • January 7, 2020
Were you able to create something that solved this issue? we are facing the exact same need and unsure of how to resolve it…
