Base to Base connection
1659 2
SHAWN_MCGIBNEY
I understand that a user can set up links connecting tables in a particular Base.
My question is, can Bases link to each other or would you have to resort to setting up the URL from that base?
Thanks, AirTable world
Shawn
Check this:
Thanks for the feedback, so at this time there is no direction to a solution except a URL in a table linking a base.
Thanks
Shawn
