Dheeraj Sudan & Meenu Hinduja - Best Way to Manage Large Linked Databases and Automations in Airtable?
  • May 14, 2026
  • 62 views
mhindujadheerajsudan
Hi All,
I’m Dheeraj Sudan from the UK. I’m a software developer and also run a business with my wife Meenu Hinduja. Now, I am working with multiple linked tables and complex automations in Airtable for project tracking and reporting. As the database grows, performance becomes slower and some automations fail unexpectedly. What are the best strategies for optimizing linked records, improving automation reliability, and maintaining database efficiency?
Thanks & regards,
Meenu Hinduja & Dheeraj Sudan
LucasPereira
Hey Dheeraj and Meenu, great question and very common pain point as bases grow. A few things that have made the biggest difference for me:
On linked records: The main performance killer is chained lookups. Every time you do a linked record → lookup → rollup → formula that references that rollup, Airtable has to recalculate the whole chain every time anything changes. Audit how many "hops" your formulas are making and try to flatten them. Also, if you have bidirectional links between tables, consider whether you actually need both directions or if one side can be removed.
On automation reliability: The most common cause of unexpected failures at scale is automations triggering on too many records simultaneously or hitting the 30-second timeout per action step. A pattern that helps a lot is building a queue with a status field (something like "Pending / In Progress / Done") and triggering automations only when status changes to "Pending", then immediately flipping it to "In Progress". This prevents pile-ups and makes failures easier to diagnose.
On general database efficiency: If your base is getting large (think 50k+ records), archiving older records to a separate base and syncing only what you actively need for reporting is worth the setup time. Also worth reviewing any "Last Modified Time" triggers in your automations since those fire on every single field change and can create a lot of background noise.
One thing that has genuinely helped me debug complex setups is using Claude with direct access to the Airtable schema via MCP. Being able to ask "why is this automation failing" with full context of how tables and fields are actually configured speeds up diagnosis a lot.
Hope this helps!
