HELP! I accidentally erased 140 records
  • Apr 29, 2021 9:58 PM UTC
  • 187 views
I accidentally erased 140 records! Yikes. The undo function isn’t remedying it. Is there another way?
Best answer by Jeb_Colwell
Check your snapshots to see if you can restore from a recent auto-save point
This will make a new base based on whatever snapshot you select, but from the new base you can export the data as a CSV and then import it back into your real one.
Oh sweet! Thanks @Kamille_Parks . You just saved me days upon days of work!
  • Apr 29, 2021 10:08 PM UTC
What happened is that in an attempt to delete a field, I pressed command+delete.
Kamille_Parks11
Forum|alt.badge.img+27
  • Apr 29, 2021 11:13 PM UTC
  • Apr 29, 2021 11:30 PM UTC
Additionally, you can click on the little trash icon right next to the snapshot icon. That will let you restore recently-deleted records, without needing to export/import.
Although note that the trash can will only show you stuff that was deleted within the last 7 days, so the snapshots would be more helpful if you need to go back further than that.
Grunty
Forum|alt.badge.img+15
  • Apr 30, 2021 11:44 PM UTC
Oh sweet!
Jeb, you marked your invocation as a solution, when you should mark Kamille’s reply instead :slightly_smiling_face:
