"IF" Formula Help
  • March 4, 2018
  • 25 views
Forum|alt.badge.img+10
Hi all!
I am stuck with a rather simple problem…
Payroll,
If you make more money in the month than you should, then transfer the overhead to the next month, example:
Salary January= 2000$
  • if jannuary is 2400$, then 2000$ in jan, and transfer 400$ to feb
Here is a simple DB link
Tnx!
:m:
  • March 4, 2018
Based on your base (so to speak), I’d create a second formula field for each month that would represent gross income. The formula would be something along the lines of
{PreviousMonthGross}-{PreviousMonthNet}+({ThisMonthHours}*{HourlyPay})
The formula for {ThisMonthNet} would be
MIN({ThisMonthGross},2000)
That’s assuming you can do all your math within each record — that is, each record contains multiple months’ worth of data for an individual. If you need to perform cross-record calculations, it’s still possible… just more difficult.
