Automation - Less than and Greater than
  • Feb 21, 2024 1:52 PM UTC
  • 104 views
For the automation above, I kept getting an error OR inaccurate output. When I would test it out and submit a 90% score, it keeps creating a record as if the score was less 89.99
Best answer by Sara11
Hi, I don't know if I'm right, but is your score column in percentage? Otherwise, the condition should be 0.90 and 0.8999 because you use a percentage, not a whole number.
Forum|alt.badge.img+16
  • Feb 21, 2024 2:18 PM UTC
  • Feb 21, 2024 2:54 PM UTC
Thanks Sara! This solved my problem~
  • Feb 21, 2024 2:55 PM UTC
No problem 🙂 have a great day
