Bit.ly Link Shortener Script for automation
  • Nov 5, 2021 1:03 PM UTC
  • 156 views
Hopefully useful for someone. If you set a variable called ‘Shorten’, then you can use this script to pull the URL and turn it into a bit.ly link which you can then use to automate something else! Feedback always welcome.
let inputConfig = input.config();
let response = await fetch('https://api-ssl.bitly.com/v4/shorten', {
    method: 'POST',
    headers: {
        'Authorization': 'API CODE FROM BITLY GOES HERE',
        'Content-Type': 'application/json'
    body: JSON.stringify({ "long_url": inputConfig.Shorten, "domain": "bit.ly", "group_guid": "THIS CAN BE FOUND IN THE URL OF YOUR BITLY ACCOUNT" })
let bitly = await response.json()
output.set("bitly", bitly)
  • May 3, 2024 11:37 PM UTC
Thanks. For some reason this isn't working for me.
I copied/pasted it directly, make a shorten field, added the API key and the group_guide thingy. And entered it into the scripts automation. Please help!
