Double Synchronization Between Two Separate Tables (not at the same DB)
  • November 23, 2023
  • 34 views
Hey everyone,
Running into a bit of a puzzle here. I'm managing our subscribers table and a CRM for member benefits. Both are on separate platforms, not even in the same database. Wondering if anyone has experience with a double synchronization setup between two tables on different platforms? Is that even doable?
Would love to hear your insights and tips if you've tackled something similar.
On a different note, www.startupbenefits.eu – offers some pretty neat resources like $750K in perks, investor databases, pitch decks, legal templates, and more. Might be worth a look if you're in the startup game.
  • November 23, 2023
Yes, it is very easy to keep 2 separate databases in sync with each other, if they each have a REST API.
You would simply use Make’s native modules (for supported apps) or Make’s HTTP modules (for non-supported apps).
If you have a budget for your project and you’d like to hire an expert Airtable consultant to help you with any of this, please feel free to contact me through my website: Airtable consultant — ScottWorld
