Help with triggering a pre-built script
  • March 10, 2022
  • 25 views
Taylor_Johnston
Forum|alt.badge.img+11
Hi!
I have a script that someone here in the community generously helped me with about a year ago.
I’m hoping to extend its capabilities by either triggering it to run via a webhook or an Integromat scenario.
I have no coding experience, so I’m hoping someone here could help me figure out how to re-format the script to be able to do this - it is currently written to allow the user to pick a record for each script run via a button field. (unfortunately, the person who built it previously is no longer active)
It is a unique numerology script.
All things will remain the same, but I hope to be able to “feed” the script the First Name, Middle Name, and Last Name fields via an automation.
If someone can help me with this, I’m more than happy to chat privately to explain more and compensate for the time and efforts spent. :slightly_smiling_face:
Here is my current script:
current script
let twoLettersToNumber = {
    "ah": 5,
    "ch": 8,
    "wh": 16,
    "tz": 18,
    "sh": 21,
    "ta": 22,
    "th": 22,
let lastLetterToNumber = {
    "m": 12,
    "p": 12,
let letterToNumber = {
    "a": 1,
    "b": 2,
    "c": 11,
    "d": 4,
    "e": 5,
    "f": 18,
    "g": 3,
    "h": 5,
    "i": 10,
    "j": 10,
    "k": 19,
    "l": 12,
    "m": 13,
    "n": 14,
    "o": 6,
    "p": 17,
    "q": 19,
    "r": 20,
    "s": 15,
    "t": 9,
    "u": 6,
    "v": 6,
    "w": 6,
    "x": 15,
    "y": 16,
    "z": 7,
 * @param {string} token
 * @param {{ ah?: number; ch?: number; wh?: number; tz?: number; sh?: number; ta?: number; th?: number; a?: number; b?: number; c?: number; d?: number; e?: number; f?: number; g?: number; h?: number; i?: number; j?: number; k?: number; l?: number; m?: number; n?: number; o?: number; p?: number; q?: number; r?: number; s?: number; t?: number; u?: number; v?: number; w?: number; x?: number; y?: number; z?: number; }} dict
 * @param {number[]} arr
function tryInsert(token, dict, arr) {
    if (token in dict) {
        arr.push(dict[token]);
        return true;
    return false;
 * @param {string} name
function nameToNumbers(name) {
    var result = [];
    for (var current = 0;current < name.length;) {
        var token = name.substr(current, 2);
        if (token.length == 2) {
            if (tryInsert(token, twoLettersToNumber, result)) {
                current += 2;
            } else {
                token = name[current];
                if (tryInsert(token, letterToNumber, result)) {
                    current += 1;
                } else {
                    throw `Invalid character found: ${token}`
        } else {
            if (tryInsert(token, lastLetterToNumber, result)) {
                current += 1;
            } else {
                    current += 1;
                } else {
    return result;
 * @param {number[]} columns
 * @param {number[]} numbers
 * @param {number} colIndex
function addToColumns(columns, numbers, colIndex) {
    for (let number of numbers) {
        columns[colIndex] += number;
        colIndex += 1;
        colIndex = colIndex % columns.length;
    return colIndex;
 * @param {number} number
function sumDigits(number) {
    let total = 0;
    while (number) {
        total += number % 10;
        number = Math.floor(number / 10);
    return total;
 * @param {{ (number: number): boolean }} predicate
function reduceUntil(number, predicate) {
    while (predicate(number)) {
        number = sumDigits(number);
    return number;
let greaterThan22 = number => number > 22;
let singleDigit = number => number > 9;
 * @param {number} firstNumberTotal
 * @param {number} secondNumberTotal
function reduce(number, firstNumberTotal, secondNumberTotal) {
    number = reduceUntil(number, greaterThan22);
    let firstNumber = number;
    let secondNumber = reduceUntil(number, singleDigit);
    firstNumberTotal += firstNumber;
    secondNumberTotal += secondNumber;
    return { columnValue: `${firstNumber}-${secondNumber}`, fnt: firstNumberTotal, snt: secondNumberTotal };
function reduceColumns(columns) {
    var firstNumberTotal = 0;
    var secondNumberTotal = 0;
    for (var i = 0;i < columns.length;i++) {
        var { columnValue, fnt, snt } = reduce(columns[i], firstNumberTotal, secondNumberTotal);
        columns[i] = columnValue;
        firstNumberTotal = fnt;
        secondNumberTotal = snt;
    firstNumberTotal = reduceUntil(firstNumberTotal, greaterThan22);
    secondNumberTotal = reduceUntil(secondNumberTotal, singleDigit);
    columns.push(`${firstNumberTotal}-${secondNumberTotal}`);
    return columns;
 * @param {string} firstName
 * @param {string} middleName
 * @param {string} lastName
function computeColumns(firstName, middleName, lastName) {
    if (!firstName && !middleName && !lastName) {
        throw "At least one of first name, middle name or last name should be given"
    firstName = firstName ? firstName.toLowerCase() : "";
    middleName = middleName ? middleName.toLowerCase() : "";
    lastName = lastName ? lastName.toLowerCase() : "";
    var columns = [0, 0, 0, 0, 0, 0];
    var numbers = nameToNumbers(firstName);
    var colIndex = 0;
    colIndex = addToColumns(columns, numbers, colIndex);
    numbers = nameToNumbers(middleName);
    numbers = nameToNumbers(lastName);
    return reduceColumns(columns);
//--------------------Airtable specific code-----------------
let columnNames = ["PK", "SK", "PT", "ST", "PG", "SG", "SD"];
const config = input.config({
    title: 'Numerology Script',
    items: [
        input.config.table('namesTable', {
            label: 'Names table',
            description: 'The table in which you track names'
        input.config.field('firstNameField', {
            label: 'First name field',
            parentTable: 'namesTable',
        input.config.field('middleNameField', {
            label: 'Middle name field',
        input.config.field('lastNameField', {
            label: 'Last name field',
        input.config.field('pkField', {
            label: 'PK field',
        input.config.field('skField', {
            label: 'SK field',
        input.config.field('ptField', {
            label: 'PT field',
        input.config.field('stField', {
            label: 'ST field',
        input.config.field('pgField', {
            label: 'PG field',
        input.config.field('sgField', {
            label: 'SG field',
        input.config.field('sdField', {
            label: 'SD field',
        input.config.table('linkedTable', {
            label: 'Templates table',
            description: "The table which the names table's PK, SK, PT, ST, PG, SG and SD fields link to"
        input.config.field('linkedTableNameField', {
            label: 'Templates table attributes field',
            description: 'Templates table field containing the values 13-4, 5-5 etc.',
            parentTable: 'linkedTable',
        input.config.field('aspectField', {
            label: 'Templates table aspect field',
            description: 'Templates table field containing the values "Physical Karma", "Spiritual Karma" etc.',
async function createLinkedRecordDict() {
    let dict = {};
    let query = await config.linkedTable.selectRecordsAsync({
        fields: [ config.linkedTableNameField.name, config.aspectField.name ]
    for (let r of query.records) {
        let name = r.getCellValueAsString(config.linkedTableNameField.name);
        let aspect = r.getCellValueAsString(config.aspectField.name);
        var key = `${name}${aspect}`;
        key = key.trim();
        dict[key] = r.id;
    return dict;
let dict = await createLinkedRecordDict();
function findLinkedRecordId(attribute, aspect) {
    var key = `${attribute}${aspect}`;
    return dict[key];
let record = await input.recordAsync('Pick a record', config.namesTable);
if (record) {
    let firstName = record.getCellValueAsString(config.firstNameField.name);
    let middleName = record.getCellValueAsString(config.middleNameField.name);
    let lastName = record.getCellValueAsString(config.lastNameField.name);
    let columns = computeColumns(firstName, middleName, lastName);
    var error = false;
    let pkLinkedRecordId = findLinkedRecordId(columns[0], 'Physical Karma');
    if (!pkLinkedRecordId) {
        console.error(`Failed to find a record with name ${columns[0]} and aspect Physical Karma in ${config.linkedTable.name} table`);
        error = true;
    let skLinkedRecordId = findLinkedRecordId(columns[1], 'Spiritual Karma');
    if (!skLinkedRecordId) {
        console.error(`Failed to find a record with name ${columns[1]} and aspect Spiritual Karma in ${config.linkedTable.name} table`);
        error = true;
    let ptLinkedRecordId = findLinkedRecordId(columns[2], 'Physical Talents');
    if (!ptLinkedRecordId) {
        console.error(`Failed to find a record with name ${columns[2]} and aspect Physical Talents in ${config.linkedTable.name} table`);
        error = true;
    let stLinkedRecordId = findLinkedRecordId(columns[3], 'Spiritual Talents');
    if (!stLinkedRecordId) {
        console.error(`Failed to find a record with name ${columns[3]} and aspect Spiritual Talents in ${config.linkedTable.name} table`);
        error = true;
    let pgLinkedRecordId = findLinkedRecordId(columns[4], 'Physical Goals');
    if (!pgLinkedRecordId) {
        console.error(`Failed to find a record with name ${columns[4]} and aspect Physical Goals in ${config.linkedTable.name} table`);
        error = true;
    let sgLinkedRecordId = findLinkedRecordId(columns[5], 'Spiritual Goals');
    if (!sgLinkedRecordId) {
        console.error(`Failed to find a record with name ${columns[5]} and aspect Spiritual Goals in ${config.linkedTable.name} table`);
        error = true;
    let sdLinkedRecordId = findLinkedRecordId(columns[6], 'Soul Destiny');
    if (!sdLinkedRecordId) {
        console.error(`Failed to find a record with name ${columns[6]} and aspect Soul Destiny in ${config.linkedTable.name} table`);
        error = true;
    if (!error) {
        await config.namesTable.updateRecordAsync(record, {
            [config.pkField.name]: [{id: pkLinkedRecordId }],
            [config.skField.name]: [{id: skLinkedRecordId }],
            [config.ptField.name]: [{id: ptLinkedRecordId }],
            [config.stField.name]: [{id: stLinkedRecordId }],
            [config.pgField.name]: [{id: pgLinkedRecordId }],
            [config.sgField.name]: [{id: sgLinkedRecordId }],
            [config.sdField.name]: [{id: sdLinkedRecordId }],
        output.text(`Updated columns for ${firstName} ${middleName} ${lastName}`);
} else {
    output.text('Please pick a record');
