Hi community members, I need help with integrations, automations, and setting-up bases
  • Jul 12, 2022 3:15 AM UTC
  • 96 views
Hi, I am looking for someone to help with integrating, and automation.
Welcome to the community, @Dominick_Davis! :grinning_face_with_big_eyes: That’s a pretty broad description. Could you please share more details about your use case and what specifically you want to accomplish?
  • Jul 12, 2022 3:38 AM UTC
Hi Justin,
Thank you, I need to create some zap automations, and help with my existing system. I have been using Airtable for 2 years now could really use assistance from someone skilled in this system.
  • Jul 12, 2022 3:49 AM UTC
Hi Justin,
@Dominick_Davis Have you checked out the Airtable Consultants Directory?
Hi Justin,
You could also post over in the #developers:work-offered category. I recommend going even deeper into your use-case description if you choose to post there. The more details you can share about what you hope to achieve, the easier it will be to find a consultant who’s a good fit.
