How to input workflow data into a JSON body through Script
  • March 28, 2023
  • 165 views
So, with my limited scripting and Java skills I've been trying to set up a script that will call a webhook so I can later trigger something there. I managed to set up the basic ping but I came across the ideal of sending some record ID's I need which can save me a step later on.
My error is surrounding inputConfig and how to parse it into the JSON body (I guess?)
The error most likely lies in line 4 and 5, hopefully it's understandable what I'm trying to get done. For line 4 and 5 I also tried "" but that simply sends over the whole thing and not the input I setup in the script (picture attached below)
let inputConfig = input.config(); let body = { "ping": "Survey Ping", "company_id":${inputConfig.contact_id}, "contact_id":${inputConfig.company_id} } let response = await fetch('https://n8n.joinowners.co/webhook-test/tally-onboardinglaunch-survey', { method: 'POST', body: JSON.stringify(body), headers: { "Content-Type": "application/json", "Accept": "application/json", }, }); console.log(await response.json());
Best answer by Ben_Young1
As some additional insight into why your original script wasn't working, you were trying to insert the values of inputConfig.contact_id and inputConfig.company_id using template literals, but you forgot to properly enclose the values inside of backticks. So you'd switch it from this:
let body = { "ping": "Survey Ping", "company_id": ${inputConfig.contact_id}, "contact_id": ${inputConfig.company_id} }
To this:
let body = { "ping": "Survey Ping", "company_id": `${inputConfig.contact_id}`, "contact_id": `${inputConfig.company_id}` }
You actually don't have to do this at all. You can actually just simply invoke the properties without enclosing them inside of the template literals like this:
let body = { "ping": "Survey Ping", "company_id": inputConfig.contact_id, "contact_id": inputConfig.company_id }
Ben_Young1
Forum|alt.badge.img+22
  • March 28, 2023
Hey @Manuel-Tanco!
Give this a shot:
const config = input.config(); const { company_id, contact_id } = config; const body = { ping: "Survey Ping", company_id: company_id, contact_id: contact_id }; const url = "https://n8n.joinowners.co/webhook-test/tally-onboardinglaunch-survey"; const options = { method: "POST", headers: { "Content-Type": "application/json", "Accept": "application/json" }, body: JSON.stringify(body) }; let data = await fetch(url, options) .then(response => { console.log(response); return response.json(); }); console.log(data)
Ben_Young1
  • March 28, 2023
To this:
  • March 28, 2023
Okay understood, I was having a hard time trying to get synced with the correct way of writing it down. Thank you @Ben_Young1 !
