Running automation by pressing button - going round in circles
  • November 1, 2023
  • 16 replies
  • 181 views
Hello
Trying to do something very basic.
I have created an automation where all the steps confirmed as working except the trigger which is a button trigger. My understanding is to connect a button to the trigger I have to select it in the interface.
So I go to the interface, add button but under Choose Automation no automations are showing. Quick Loom here.
Any help much appreciated!
  • November 1, 2023
Very bizarre. I setup my base the same way as you did, and on my interface, I *am* successfully seeing the list of automations that are set to the "button trigger". So I'm not really sure what's going on! What happens if you delete and re-create your interface page from scratch all over again? Same problem? If so, you might need to reach out to support@airtable.com about this issue.
  • November 1, 2023
Tried that and not changed!
Arthur_Tutt
  • November 1, 2023
@unserrer so close - right below where you're clicking is the automation select 🙂
  • November 1, 2023
That's the problem - it won't let me press that!
Arthur_Tutt
  • November 1, 2023
@unserrer When you setup your interface, were you able to select the table and records? This forms the basis of the source for the interface.
From the interface setup steps:
  • November 1, 2023
Where is that setup page? I dont recognise it?
Arthur_Tutt
  • November 1, 2023
@unserrer From your Interface page click the '+' button to create a new interface OR click 'add page' to configure a new page (if you don't see that option, click on the white space inside your interface).
Arthur_Tutt
  • November 1, 2023
@unserrer one more question - what style of layout are you using for your interface? (List, Record View etc..)
  • November 1, 2023
So here's my Loom. I'm wondering if because I'm using blank to start with the button isn't given a source? I'd like to use a list but can't put a button on a list interface from what I can see.
Arthur_Tutt
  • November 1, 2023
Got it @unserrer - thanks for the video that was very helpful! So I believe in this case the issue is the 'Blank' template, which is not properly connecting to your table/records.
Remember that a trigger for an automation has to be triggered from a specific record, but in List View with all records present, Airtable won't know which record triggered it. See the problem?
A couple thoughts:
Could you try creating a Record Review style layout and then add your button and list as elements? (screenshots).
If that works, great. If not, can you tell me a little more about what your automation is intended to do, and what data it needs to trigger? There might be better ways of setting up the trigger for the automation.
  • November 1, 2023
A couple thoughts:
Let me try and explain what I am trying to do.
I have a whole bunch of records. I want to go through them, select a few (have created a checkbox property so that the automation can work with them) and then output the records I have selected to a CSV.
Ideally list interface would be best so I don't have to go through each record.
Arthur_Tutt
  • November 1, 2023
hey @unserrer alright I've got something for you. May not be a perfect solution, but will get the job done. As I understand it you've got the export to CSV automation working fine, it's just about having the correct trigger to launch it. Recorded a Loom Video to take you through step by step. Here's my example:
*** Remember to change all my Table / Field / Variables to match yours ***
Base Setup:
Automation Trigger Setup:
Automation Script (to get data of ALL records with export box checked)
var dataTable = base.getTable("Form Data") var dataQuery = await dataTable.selectRecordsAsync({fields: ["Field A", "Field B", "To Export"]}) var dataRecords = dataQuery.records; console.log(dataRecords) var exportDataType = dataRecords[0].getCellValue("To Export") // console.log(exportDataType) var exportedData = []; for (var i = 0; i < dataRecords.length; i++) { if (dataRecords[i].getCellValue("To Export") == true ) { exportedData.push({ "Field A": dataRecords[i].getCellValue("Field A"), "Field B": dataRecords[i].getCellValue("Field B") }) } } console.log(exportedData)
 Automation Output:
  • November 1, 2023
Base Setup:
 Automation Output:
That's amazing! Thank you so much! I've still got my fundamental question though - my automation seems to work but Airtable isnt letting me assign an automation to the button!
Arthur_Tutt
  • November 1, 2023
@unserreryeah it's super frustrating, but I think you're trying to do something that Airtable is not designed for (hence why the automation option is grayed out for you).
I gave you a solid workaround, will it get the job done for you for now?
  • November 1, 2023
Am going to try that tomorrow thank you! Really!
Arthur_Tutt
  • November 1, 2023
Awesome, let me know how it goes!
