Script extension does not act the same in Automationn
  • October 26, 2023
  • 95 views
I wrote this code and it works perfectly as I want in Script extension but in Automation it is a mess.
The first part of the code works fine in automation but not the second part, so only the second part needs to be adjusted. Here is the whole code :
// first part of the cod
let poTable = base.getTable('PO');
let transpoTable = base.getTable('Output');
let poRecords = await poTable.selectRecordsAsync();
let transpoRecords = await transpoTable.selectRecordsAsync();
let artikelDatumQtyMap = {};
for (let poRecord of poRecords.records) {
  let artikelID = poRecord.getCellValue('Artikel ID');
  let eta = poRecord.getCellValue('ETA');
  let qty = poRecord.getCellValue('Qty');
  if (artikelID) {
    let artikelIDMatch = artikelID.match(/^(\d+)$/);
    if (artikelIDMatch) {
      let artikelIDNumeric = artikelIDMatch[1];
      let artikelColumn = `I ${artikelIDNumeric}`;
      if (!artikelDatumQtyMap[eta]) {
        artikelDatumQtyMap[eta] = {};
      if (!artikelDatumQtyMap[eta][artikelColumn]) {
        artikelDatumQtyMap[eta][artikelColumn] = 0;
      artikelDatumQtyMap[eta][artikelColumn] += qty;
let transpoUpdates = [];
for (let transpoRecord of transpoRecords.records) {
  let datum = transpoRecord.getCellValue('Datum');
  let updateFields = artikelDatumQtyMap[datum];
  if (updateFields && datum) {
    await transpoTable.updateRecordAsync(transpoRecord, updateFields);
// Second part of the code
let columnNames = transpoTable.fields.map(field => field.name);
for (let columnName of columnNames) {
  if (columnName.startsWith('I ')) {
    let recordsArray = transpoRecords.records;
    let firstNonEmptyCell = recordsArray.find(record => record.getCellValue(columnName));
    if (firstNonEmptyCell) {
      let firstValue = firstNonEmptyCell.getCellValue(columnName);
      let updates = [];
      let total = 0;
      for (let i = 0; i < recordsArray.length; i++) {
        let transpoRecord = recordsArray[i];
        let cellValue = transpoRecord.getCellValue(columnName);
        if (cellValue !== null) {
          total += parseFloat(cellValue);
        updates.push({
          fields: {
            [columnName]: i >= recordsArray.indexOf(firstNonEmptyCell) ? total : null
        if (updates.length >= 50 || i === recordsArray.length - 1) {
          await transpoTable.updateRecordsAsync(updates);
          updates = [];
The result that I want and that I get in the extension is this :
but I get this when I run it in automation:
I noticed that the extension and automation doesnt run the same way but i don't know what to change to make it work like in the extension.
Thank you 🙂
  • October 26, 2023
I don’t see anything in your code to explain the different results. But your code is a little hard to read, so I cannot say for sure. For example, you declare the variable transpoUpdates, but I cannot see where you use it. You also have an async call insides a loop, which sometimes causes problems, but doesn’t seem to be the issue here. Could you have different sorting or filtering going on in your views to account for the differences)
  • October 26, 2023
Hi, yes true you are right I dont need this variable, I removed it but it changes nothing to the result
  • October 26, 2023
I didn't expect removing the variable to help. I was just pointing it out as an example of why the code is hard to read. There are other reasons why I found the code hard to read, but that are more complex to explain.
Have you looked into the view filters?
  • October 26, 2023
I have done with and without filters, and it changed nothing, I cannot understand why it puts the result so randomly in the table
